box question for a sedan bimmer
Audio Master
ok this has been asked before probably but i cant find it im using the box designs on the box designs thread and the 4.6cubs @35hz design now it has a front firieing set of subs and the port is the same
my qestion is will this work well in a trunk of a E34 5 series bimmer and in which direction should i fire it as there is only a small ski hole to get the sound into the cabin shoul i put the port in the middle of the subs and face towards cabin or should i leave it as a side port and aim it backwards to the rear of the car to create bass load
all help
is helpful thanks heapz pepz:veryhapp:
I'd do port back subs back and not fire it into the "ski hole" if you put it 180degrees away from a sub it tends to leave the door open for the sub to unload, and damaging it severely.
remember sound does pass through objects so its not like you have to funnel it through like water..
Audio Master
Audio Master
Perth, Western Australia, Australia
AllDayMJ
ThxOne
    May 13, 2026
ThxOne
    May 13, 2026
