Box Port Direction
  • 6
bmk6795
What's up guys. Gonna be building a box for a hdc 3 12 in a 2013 civic. Just have a question regarding port orientation, should I fire sub/port back or sub back port to side? Not going for numbers or anything just a daily woofer. I've always done both back, what would you guys do?
yeah if both back sounds good i'd keep it.. only way i would change it is if u have friend with side port box u can try before u build or buy side port box.. sometimes sounds ok sometimes doesn't work at all depends on car so gotta test 1st.. mine (3cars) always sounds better firing rear..
I'm trying to do 4 18 inch resilient sound platinums in a cpillar flat wall .4 to 5 cubes per was told they like 12 to 16 inches per cube . I have...
440
636
bmk6795
bmk6795
Spartanburg, SC
Boomin_tahoe
    May 31, 2024
    May 24, 2024
