Just bought one of these off ebay and should get it in a couple of weeks. When I get it I'll be using it in a 1cuft sealed box until I build a better one. Soundstream recommends a 1.25 sealed for max output and a 3cuft sealed for max sq. It doesn't say much about ported boxes for this sub. My plans are to make a 3cuft ported box tuned at 32hz using 3/4" plywood. The box will have external dimensions of 26.5"x24.5"x10.5" and the port will be 3" diameter and 4" long (calculated this using an online calculator).
Just wanted to know what others thought of this as it will be my first box design and if 32hz would be a good idea to tune to (also not too sure if 3cuft is a good size). Info on the internet suggests 30-35 hz tends to be the best, lower for rap music and higher for rock. I listen to rap music maybe 30% of the time but usually I listen to reggaeton if anyone has much idea what that is lol, it still has lows but doesn't hit as low as rap usually does. Sub specs below if ya need it.
Sub specs
RMS - 350W
Fs - 32.87 Hz
Vas - 1.839 cuft
Qms - 4.963
Qes - 0.733
Qts - 0.638
Xmax - 0.413"
SPL - 89dB
Any feedback at all on this box is appreciated, I'm looking at a significant upgrade from my current kenwood sub. Oh and how will this sub run in a 1cuft sealed box if 1.25 is suggested for max output will it be able to handle the 350WRMS or will it bottom out in this smaller box?
Cheers.
Sub specs
RMS - 350W
Fs - 32.87 Hz
Vas - 1.839 cuft
Qms - 4.963
Qes - 0.733
Qts - 0.638
Xmax - 0.413"
SPL - 89dB
Cheers.
