box mounted amp
As long as your enclosure is built solid with no flex, there are no issues with mounting your amplifier to it.
alright cool. the box is sturdy and made of 3/4 mdf and only like 700 watts so i doubt there's gonna be much flex.
thanks guys
If your box is solid it's not a problem except the vibration with more powerful setups, I usually put small wire grommets in between the amp and box when mounting to the box...
ill go get some little foam pieces and cut them into little squares and put them in between the mounting tabs on the amp and the box.
casedawg350
casedawg350
IN
casedawg350
