germanyt
Well, I got the replacement nine.1 yesterday and installed it. This on is putting out the right voltage so I know it works but still no output. I started feeling around the outside of the beauty baffle I made and I think I can feel some air leaks that aren't coming from the port. I'm not really familiar with how a leaky box sounds so here is the symptom. At nearly full tilt the subs barely move. I have to put the bass on the h/u all the way up with gain half way to get any real bass out of it and it still in no way compares to the bass before I made the beauty panel. It also sounds very midbassy. I played around with the filter and x over but no good results. Songs that should play in the low 30s sound like mid 50s or 60s. Test tones at less than 30 Hz cause the cone to travel way farther than it was previously (w/o the beauty) but almost no output. It's almost like the sub is playing in free air. Because I eyeballed my mdf ring placement when I glassed the original front baffle my new beauty baffle didn't quite sit flush against it. I used bondo and thought I got it all filled in. Then I glassed the gap just inside the mounting hole where the new baffle was about 1/4 to 1/2 inch from the old mdf rings. I thought this would do the job and thought I did a pretty good job but maybe not. Any Ideas?
