tukn18s
Help me decide! //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
They have some specs on the manufacturers website, but are those always the best way to go? I'd like to run a slot port, but am open to anything. Can someone model it for me to tell me what the best response will be in? Maybe it'll work great sealed? I don't know //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Thanks in advance for any help, I have provided the specs from the website.
Power handling RMS / Max 1500 / 3000 Watts
Impedance 2 x 2 Ohms
Voice coil diameter 100 mm
Voice coil winding height 57.5 mm
Max. linear excursion +/- 23 mm
Cone area 520 cm²
Moving mass 241 g
DC resistance 2 x 1.6 Ohms
Resonance frequency 31 Hz
Mechanical Q factor 2.92
Electrical Q factor 0.57
Total Q factor 0.47
Equivalent air volume 38 L
Voice coil inductance 1.97 mH
Force factor 18.5 Tm
Efficiency 1 W / 1 m 85 dB
Outer diameter 322 mm / 12.68“
Cutout diameter 287 mm / 11.30“
Mounting depth 209 mm / 8.23“
Recommended enclosure
Sealed box
Sealed net volume 45 L
Ported box
Vented net volume 70 L
Port diameter 10 cm
Port area: 80 cm²
Port length 35 cm
Cone area 520 cm²
Moving mass 241 g
Total Q factor 0.47
Sealed box
Ported box
Port diameter 10 cm
Port area: 80 cm²
Port length 35 cm
