Box for Fi Q 12
djazmatic
So, I'm trying to get some dimensions down to build a box. I want it to be 2 cubes @ 32 hz
I used this calculator to get the info for me. I just wanted to make sure everything was correct before I went ahead and started building it.
Heres the link:
http://subwoofertools.net/Calculator?Driver.SizeId=12&Driver.Qts=.45&Driver.Vas=48.3&Driver.Fs=28.4&Driver.DriverDisplacement=276.48&Driver.Xmax=27&SubwooferSystem.DriverCount=1&Enclosure.Width=33&Enclosure.Height=15&Enclosure.Vbr=2&Enclosure.Fbr=32
It gave me 33W x 15H x 16.25D (I have 35Wx18H trunk space)
Let me know if everything there is giving me correct info or if I filled any section out wrong.
This is for a single 12" Fi Q Dual 1ohm.
Specs:
Q12
DUAL 1 | DUAL 2
Fs: 28.4 Hz | 27.1 Hz
Re: 0.7 Ohms/coil | 1.4 Ohms/coil
Qms: 05.39 | 5.63
Qes: .49 | .48
Qts: .45 | .44
Mms: 211g | 231g
Cms: 0.15mm/N | 0.15mm/N
Sd: 481cm^2 | 481cm^2
Vas: 48.3 l | 48.3 l
Spl: 85.4dB 1W/1m | 84.8dB 1W/1m
Bl: 10.4 N/A | 15.1 N/A
Xmax: 27mm
Rms: 1000W
Sealed box: .8-1.5 cuft
Ported box: 1.8-2.5 cuft @ 28-33Hz
Sub OD: 12.500”
Cut ID: 11.125”
Mounting depth: 7.000”
Displacement: 0.16cuft
Thanks!
Hey man, I used my calculator and got alot different results.... however you didn't mention the port configuration you input to the other program....
Okay, if you want a box 33w x 15h with a 4" aero port the box will need to be 10.75" deep and the port will need to be 14" long.... kinda hard to work out with that port length.... However, if you choose to go with a slot port then your box would need to be 33w x 15h x 13" deep the port would be 2.75" wide x 11.5" tall and need to be 29.5" long to tune to 32hz..... these are all outside dimensions on the boxes and include port and subwoofer displacements....
I just built a 4.2cuft slot enclosure for my 2 Fi Q 12's.... can't wait to hear them, still have to paint the box.........
Alright thanks. I got someone helping me on the box build since this would be my first build. I'll def. have him take a took at the dimensions you gave me.
djazmatic
djazmatic
Chicago, IL
4OZGLOVES
