- Thread Starter
- #16
Actually enclosure design overall will drastically change/alter performance of the sub stage. As simple as moving the sub side to side on the mounting surface will alter performance by more then 1%.
Being sarcastic to some one that took their to help you is not how things are done around here. Perhaps looking into things as they are will fix this issue for you.
If you design as you suggest you do, then I would suggest you try and do more research on your own about that subject. Unless your analogy is grossly exaggerated at a poor attempt to be witty with incorrect information.
Every box I have designed has came out fantastic and I never said I was good at math lol you really need to learn to read. I said if something makes sense and is physically possible I believe it, physics aren't hard and I don't really consider them math mostly common sense. I think you guys are over thinking the whole move the subwoofers thing, because that's never changed a **** thing for me in any build not noticeably anyways. But you can believe what you want.
