box for an sx 18"
coolahan
141.6 dB @ 36hz
For an RE SX 18"... just wondering if you guys think this will work out nice..
Sub is going to be playing upwards.. port going out back..
Number of subs : 1
Box type: Vented
Box size: 7.000 ft^3
Tuning frequency: 34.00 Hz
Wood Thickness: 3/4"
W: 36"
H: 20"
D: 20 1/2" (little less than half)
Vent: 1 vent
17.34 in length
34.50 x 2.75 port dim.
What do you think? Input is greatly appreciated.
should sound good, i think Mannyb is 8cu and it hits hard as hell, but his sub fires frontward as well as the port.
with those numbers (my math sux) i didnt get 7 cubes though
WinISD did the sq ft math... and does making it fire frontward really make that much of a difference? .. cause i wanted to look in the rear view mirror and smile when i saw the EXCURSION! but i mean i could make it a little bit taller and make it fire frontwards if it makes a noticable difference.
also, running the port like you would like too you are looking at about 1.2 cube of port disp, and the SX 18's disp is about .2 if I remember correctly.
So basically that box will end up being about 5.6 cube.
With those EXTERIOR dimensions give your getting 7.0177 GROSS volume. Thats before driver and port displacment. Readjust your numbers bro.
EDIT: Beat me to it Mikey //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
do you guys think that firing the sub forward would be a noticable difference over firing it upward.. and i can make it a couple inches taller to get some more sq ft... but i mean the ideal space for the sx 18 is 5.6ft^3 anyways isn't it? thx for doing the math guys..
i think that is realy vehicle dependent when it comes to where you point the subs.
in an suv i have had great success installing them firiring them upward. but since there is so much open area in an suv. i realy dont think it will make that much of a diffrence.
a good way to test is if you have a small enclosure and sub, power them up and see what works best and go with that.
id put the sub and the port on the same surface if you can, then you can face box up or forward or backwards depending on what sounds best, with the sub and port on different surfaces your risking weird phaseing / cancellation issues ( i think?)
the only numbers taht i looked at was the H x W of the port, and thats ging to have some nasty turbulence as well as lose much output due to the ratio being so far off.
you dont want to go over 1:9 in most cases.
coolahan
141.6 dB @ 36hz
coolahan
Oklahoma
bamaboy
Mike Mccabe
