Box construction help!
Hello guys. I got a sub which at the moment its 1 but soon its gonna be 2. which i want to install in my car's trunk. I need info (after regarding port,tune threads etc) on the following matters(questions at the last) Specs are all listed below:
Want to install : 1 x cerwin wega sub vmax 15.2
Subwoofer Size 15"
Voice Coil(s) Dual
Impedance (per voice coil) 2 ohms
Peak Power Handling N/A
RMS Power Handling 600 watts
Woofer Composition N/A
Woofer Surround Oversize Ellipsoid
Sensitivity 87 dB
Frequency Response 20 - 500 Hz
Xmax (millimeters) 17 mm
Top Mount Depth 7-1/8"
Cutout Diameter 14-3/32"
Car i am using: Trunk of toyota corolla 2009.with 1/4 of the space consumed by other stuff!
Question: Which mono amp to use with these sub. I plan to use 2 mono amp seperately with each woofer. or should i use 1 for both of them. Amps considered are of pioneer,kenwood,orion.
2nd question: the box size,type. Please note that i will add another woofer later on this year, so need to know the dimensions of the box.
I require loud sound that has low punchy bass! which addditional stuff can i do.
I already have 4 components in the front door 1720c pioneer, 2 6975V2's in the back, on pioneer d9500f amp and d510m also pioneer, with avh4150 and 2 x kenwood 3010 mounted inside the rear seats. with 2 bosch batteries, 2x 4 caps!
Thelivingflesh
Thelivingflesh
London, United Kingdom, United Kingdom
Thelivingflesh
