Box Building Tips Thread
My advice is very simple. DO NOT USE THE PREDRILL and SCREW METHOD. Far too much time is wasted. Invest in a brad nailer that is capable of shooting brad nails up to 1 1/2" long and a fairly decent air compressor. It's always funny when people come over to my house and see the simple setup that helps me bring the wang. I have a craftsman compressor that cost $100 and a brad nailer from Harbor Freight that cost $35. I challenge anyone to say I'm wrong because in the end it's all about the glue that you use and the pressure applied to the joint.
Router with jasper jig and spiral upcutting or double fluted straight cutting bits for sub and speaker terminal holes.
1-5/8" coarse thread drywall screws, 3/32" predrill bit with countersink
If painting the port tape off areas that will be bonded to other wood or carpet.
.....X2...I also recommend cutting ALL of your pieces first...then assemble.
Sometimes, if you're inexperienced, if you're off by a 1/8 or so by the end of the project it can be safe to wait to cut your last piece. More often than not a trim bit will take care of this problem though.
I agree with you on the part about glue being the strength of the joint. However, I have expressed my .02 on brad nails vs. scrwes before... and Ill stick with screws //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
ALL A MUST! you dont need a router if money is tight. if you have a jigsaw you can get pretty handy with one. ive gotten pretty good freehand with my jigsaw skills.
Agreed. I only learned about using a nailer to help recently. Also makes up for not having a lot of clamps. My current box has titebond II, brads and pre drilled screws.//content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif
Also recently learned was taking a piece of wood and outline the edges to show you where to nail and screw. Very handy.//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
true on that brads = faster. I still like screws in birch those ends just don't glue as well as mdf. Mdf loves the titebond and really any good glue except liquid nails. I have been using a bunch on loctite 9887 grey RTV lately for sealing boxes I got for free from my friends trike shop. They got the wrong kind so I got 200+ tubes for free its worth 17 a tube. otherwise some ghetto sealant is fine but only MMM glue is good for carpet.
I would love to hear the enlighted explanation. I've never seen an accurate comparison before //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif.
When i assemble my box together, gotta have plenty of all sorts of clamps- clamps, L clamps, furniture clamps, they all come in handy.
I use Titebond II\III as the adhesive glue, then i use Liquid Nails as a bracer\sealer inside the box on all corners\adjacent pieces then I finish that off with silicone along the same areas as the Liquid nails.
A Good Tip-
If you get a lot of Liquid Nails on our fingers because you spread it with your finger, spread silicone with your finger too, //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif silicone mixed with LN will get it off your fingers in no time.
Also, if building a smaller box, i use 6" L brackets every 12in on all 6 sides of box if necessary to maintain strong structure where 2 pieces meet. The 6" L brackets have a 10-12" structural strength radius before it looses effectiveness.
If building a large box, bracing with 3\4" All-thread with 1\8" Steel runs from point to point will give outstanding bracing strength. Finish the All-Thread off by welding ALL cross sections inside the box. I always glue the steel as well to make sure that all areas between point A and point B are connected with the steel.
uGotF-ckedUp
uGotF-ckedUp
platte south dakota
Enellz
