box build, 2 12's
Exploder 97
Monte Carlo SS now!
Need a box spec sheet. Here are my specs
34 wide, 14 tall, 20 deep. 2 12".I want the port to be in the middle if possible a square one in the middle with 80 inches of port tuned to 35 hz, 4.0 cubes.. Ill give you some money through paypal if you include cut sheet.
give your dimensions, 3.9 cu ft, 35 hz. 3 4" tubes
That is probably the best you can do given the size requirements. A slot or square port takes up too much internal volume so tube ports should be used. The 4" precision port kits are sold at PartsExpress and eD. The ports were placed on the side because the length of the ports are too long to place them on the front.
Exploder 97
Monte Carlo SS now!
Exploder 97
toledo
Exploder 97
