Box/amp rack for my daily driver
orangelss
Here is a couple sketch up drawings of the amprack box going in my Focus. Box will hold a TC Sounds LMT 12 with 2x15" VMP passive radiators. Modeled on Unibox. 3.8cft and tuned to 28hz. Sent design to BJ Fisher, hope he has time to do it!! Amps are a Sundown 1500d and 100.4d. Blue box is my Kinetic battery and Aqua boxes are my fused ground and power. All wiring is KnuKonceptz. All wiring will be tech flexed and heat shrinked. Will also have a beauty panel made so only the amps are visible with the seats down.
1500d will power the 12" at 3ohm, 100.4d will bi-amp my front stage. Illusion Audio horns and TC Sounds RMB6.5s or Aura 8s. All processing will be done with my Pioneer 800prs. Sweet and simple. Hope to get started deadning and wiring the car in a couple weeks.
Here's some of the equipment going in. Waiting on Heatshrink, passive's, and the Illusion horns. Have to pay the rest of the $ for them. Well onto the ****!!
Wiring with Tech Flex
Rare Tc Sounds RMB6.5s
Aura Shallow 8s. These are the McIntosh versions for the Ford GT400
LMT4000 12 from Spy
Vifa XT25s if I find I need to bring the soundstage up. Will mount these in the A-pillars
are you going to have sufficient airflow around the amps so they dont overheat?? like puttn fans on the sides or sumthn?? i know its open back but it still might be a good idea
**** bro nice gear. You don't see too many passive radiator setups. I had the OEM 10 w/ passive radiator and it sounded nice. I thought you're only supposed to go twice the size of the sub you're putting in though?
Could get by with one 15"pr and add more weight to it. Have 2 so I modeled a box using two. Nice smooth curve and if I decide to tune lower makes it even eisier.
orangelss
orangelss
Sedalia
orangelss
