Boston Acoustics GTA-1105 5 Channel
06gtmike
Item(s) for Sale: Boston Acoustics GTA-1105 5 Channel
5-Channel Class AB/D GTA Series Hybrid Amplifier
RMS Power Rating:
4 ohms: 70 watts x 4 chan. + 250 watts x 1 chan.
2 ohms: 125 watts x 4 chan. + 400 watts x 1 chan.
Bridged, 4 ohms: 250 watts x 2 chan.
MOSFET power supply
LED power and protect indicators
SST (Symmetrical signal Topology) system uses balanced asymmetrical inputs for noise cancellation
Fully adjustable Q-Tune circuitry for simple bass output optimization
Recessed control panel for clean installation
IMS (Integral Mounting System) reduces the amplifier footprint
All input/output connections are located on one side of the amplifier to ease installation and wire management
Optimal angled speaker and power blocks for easy wire connections
5-Channel operation
Speaker-level (high-level) inputs with signal sensing for automatic turn-on
Preamp rca outputs to daisy chain multiple amps
3-Way System Protection circuitry (thermal, overload, and speaker short protection)
Fully adjustable and selectable lowpass/highpass crossovers
Wrap-around heatsink design for extreme heat dissipation
Gold-plated rca level inputs
Gold-plated screw terminals
Variable High-Pass Filter (50-200 Hz, 12 dB/octave)
Variable Low-Pass Filter (50-200 Hz, 12 dB/octave)
THD (Total Harmonic Distortion): 1%
Signal to Noise Ratio: 90 dB
Frequency Response (Front/Rear Channels): 10-50,000 Hz
Frequency Response (Subwoofer Channel): 10-50 Hz
Input Voltage: 14.4 volts
Fuse Rating: 25 amp x 3
CEA-2006 compliant amplifier
Dimensions: 8-3/8"D x 21-1/4"W x 2-3/8"H
Item(s) Description/Condition: 100% working and great overall cosmetic condition with one small scratch on top and a scratch on the bottom that you would never see anyways. Comes in the original box with the manual.
Price: $175 shipped. Not looking for anything trade wise but I can always be persuaded with the right offer.
Shipping and Miscellaneous Item Information: Included
Best of luck on the search of these Gems 👀 👀 💩
Massive doesn't provide much technical detail on the CT2, but looking at the response curve suggests an FS of ~1.4khz and the listed frequency...
15
06gtmike
06gtmike
Williamsburg, VA
2012ScionTC
