bondoglass for door pods? *pic*
Rsx_03
LoW aNd sLoW
i want to add a little bondoglass to blend the ring into the door then paint it. if i drill little holes and scratch up the area i want to bondoglass, will it hold?
should i put a peice of cloth+resin first then bondoglass over it?
advice please
oh and i couldnt find nonharding clay, i filled the back of the ring in with silicone, is that just as good since it adds mass?
and i wouldnt of used silicone to pack the speaker ring...too alte now tho... modeling clay is well i have only ever seen it talked about here and not anywhere else really and i have never used it or needed it. I just toss some left over strips of deadener or some cork diy gasket material behind the speaker and its always fine...
I used silicone on my speakers i place it in between the speaker and the mdf ring and also on the mdf side that i mounted to the door and it seals just fine not a problem at all.
good so i dont have to wait for that resin to dry
its going to be a thick in some areas cause the ring is like 3/4" thick and i just screwed it to my door, doesnt bondo crack/warp? is bondoglass kitty glass?
i added the silicone to add mass to suposably add more midbass, plus i dont really like it being hallow behind it
Rsx_03
LoW aNd sLoW
Rsx_03
miami
Rsx_03
