just a thicker primer that kind of lays itself down into the cracks and such..how well does the high build primer work?
sand first. you don't need to sand the paint off, just get it 'roughed' up so the primer will stick.well i ended up gettin a gallon of bondo for $10 last nite- seemed cheap so i decided to go this way.........
my box is already painted so do i need to sand it down then spray on primer or can i just add the bondo and get started?
Slicksand that and be done with it. slicksand is unlike any regular high build primer and has the consistency of water. look into it, but its pricier.i gave up trying to get a surface for my pods without dips, so once i have sanded the bondo smooth, your saying, cover it in resin, sand it, high build primer it, then paint it. sounds like a good idea...
that will work.so just like regualr spray can primer ?
that one/\Slicksand that and be done with it. slicksand is unlike any regular high build primer and has the consistency of water. look into it, but its pricier.
