boat tower speakers
clotus
First time post. I have installed the infinity tower speaker system on my boat. They are not the best, but do the job. Only issue is the speakers are heavy and I have to completely remove my tower for storage. The speakers do not have any quick disconnects and would have to be completely removed from the tower (read PITA). I was wonder if anyone had any ideas on quick disconnects without having to remove the mounting brackets. Thanks.
-Kyle
Edit: removing the entire speaker, not just disconnecting the speaker cable, I know how to do that //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
//content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gif
Huh?
Dpending on the tower, you should be able to just unscrew them and disconenct the wires.
Ya I know that, but the mounts are difficult to put on the tower. I was hoping someone had a similar problem or knew of a simple solution to keep the mounting brackets on, but be able to remove the speaker. The speakers hang down on about a 1" diameter post that allows them to swivel. If there was a way to disconnect them from from the post it would be a lot easier to put it back without having to remount them. I knew it was a long shot, but thought I would ask around. Any thoughts.
clotus
clotus
Los Angeles, CA
clotus
