BNIB TC Sounds 5200 Custom splaudio softs
disturbed471985
Freshly saturated in late 2016 at Sundown TC5200 motor. Black 15" TI style basket with black mesh. QCA assembly. Brand new in box Corey splaudio drop in. Spl surround, 4layer eco high temp 4" coil. Triple dual layer 10" full nomex linear red spiders. Triple fully sewn leads with JY Power 8awg ofc directs. Rated at 5k rms. Dual 1ohm but reads .8ohm on my DMM. Selling cause ill never get around to using it been sitting boxed 4-5 months. No need to explain what the 5200 is. Was built to be powered by an Vital Power 7k and optimal box would be rd 3.5cf with said power. No expense was spared on this sub. $1500 Team sub or the OG and in many ways better TC beast.
Over $770 in receipts...
GUYS I CAN NO GET PICS TO ATTACH ANY HELP YEA..
318/801/201one
Priced $400 or can drop $1300+ on a Team easy choice..
Wish you had 2 of them. BTW, what is the stuff that is inside the hole the voice coil goes in? Does that need to be drilled out? How do you align the voice coil?
U want and if u do expect 300+ on jus motor that has not been resaturated.
I'd like to get something roughly equivalent to the Eclipse TI Pro 15-meaning a high Xmax, small enclosure sub. Would this be that?
this sub is way waaaay better than the eclipse TI pro. absolutely monster of a sub but i wouldnt go small enclosure if you are going for lows.
If plan on giving sub its rated 5k clamped as I was 3.5 tuned to 33-35hz. Less power bigger you can go on box. 6 layers of full nomex will keep cone under control in a variety of applications vs the stock 2 layer it had
disturbed471985
disturbed471985
Greenwood, La
tymoto21
    May 12, 2024
Brendon Jenness
    May 11, 2024
