BNIB HIGH END QUALITY SPEAKERS!!! 2007 Manf. date!!!
iLLsT0LZ
Mi
2 (two) brand new in the box audiopulse axis 12 q1's!!!!
Mint 10 out of 10 in every aspect. have taken them out of the box to look at them.
The all new Audiopulse AXIS is designed with high motor force, long excursion and very high power handling to provide loud deep bass in the mobile environment. Many drivers fall short these features and relying on large box volumes to make up for low frequency efficiency, but the AXIS doesn’t need any help, with 40+ pound motor, flat-wound conductor on a triple reinforced heatsink former and all the BL product in the world, it works harder so you don’t have to give up half your car to a large subwoofer box.
Engineered for world class performance, the AXIS delivers vision blurring SPL with unparalleled low distortion bass that will land a grin on your face every time. This driver doesn’t just belt out SPL with compromised xmax as many typically high output drivers do. It does it with a class leading 10” linear suspension system, tall surround and extra long voice coil to dig for that extra octave other drivers just don’t consider. Combine that with particular attention to linearity and distortion prevention methods such as our large Faraday ring to reduce inductance and diminish non-linear flux modulation distortion that many SPL drivers suffer from drivers suffer from, and you’ll wonder why you would ever own any “SPL-only driver” again over this addictive combination.
Not to be overlooked, the voice coil in the AXIS is nothing to ignore. Designed to be substantial, effective and unchallenged, this 3” voice coil with ultra high packed flat wound aluminum wire is as stout as they come. With enough conductor cross section to silence non-linear eddy current distortions within the former itself, this is truly a low distortion LFE high power design. Comprised on an anodized aluminum reinforced heatsink for 3 times the thermal conductively of normal aluminum formers, the excess heat is pulled away from the voice coil and displaced over the surface area of the conductive cone which is then air cooled instantly. Make no mistake, the AXIS doesn’t just take burp power, it takes more long term power than 3” SPL burp driver ever could.
Only Audiopulse drivers can truly fulfill the promise of ultra high SPL with ultra low distortion, and the AXIS is the best “daily-driver” woofer combination of the two. Truly a delicate balance of vigor, girth and agility without sounding imprecise; indeed, the quality and performance of this driver will leave you feeling quite satisfied that you own the World’s best.
Design
Flat-wire technology for excellent conductor packing density
High thermal dissipation former heat sink design for improved compression limits
Long throw high temp 3″ wide voice coil
10″ linear suspension system with large lead wires for improved durability
Patent pending NBR tall profile FEA surround for excessive travel
Massive 3.5″ conductive shorting ring to improve linearity
Single dish anodized and powder coated alloy heat sink cone
Patented field replaceable top assembly system makes “recones” obsolete
Patented exclusive high excursion frame assembly
High BL promotes inherent small box design to save space without compromise
Distinguished metallic clear blue triple layer powder coated frame
Available in 12″, 15″ and 18″ sizes
695 Shipped conus!!!!
Parts express says 2" peak to peak:Audiopulse AX12Q1 AXIS 12" Quad Coil Subwoofer 293-620
GLWS nice subs
these are not the same woofers. These are made with different soft parts, different coils, different cones/surrounds, and different baskets.
these will do 3" peak to peak without bottoming out. It states on this website they will do 30mm one way excursion which comes out to just shy of 2.5 but i know for a fact they are capable of 3" they utilize a softer suspension than the new tc axis, and have WAY better build quality then the chinese equipment they are producing now. Also i believe there is a slight variation of the 3hp motor compared to the new style tc sounds axis.
Audiopulse
To the top, anyone who knows anything about these woofers feel free to chime in. I dont want to split hairs over a subwoofers 1/8" of excursion before break in lol.
here is some more info, from the newer style woofers, with more restrictive stiffer style spiders. my point being is that these will do 3" peak to peak without bottoming out. I have dealt with plenty of tc/audiopulse/soundsplinter woofers. And know this for a FACT on actual experience with said driver.
http://tcsounds.com/wp-content/uploads/2012/08/Axis-12-Owner-Manual.pdf
iLLsT0LZ
iLLsT0LZ
Mi
iLLsT0LZ
michigan born
    May 14, 2026
michigan born
    May 14, 2026
