Blue/White Wire?
  • 4
Okay, so I just wired and installed my head unit. Everything works well all speakers work and sounds great.
One question though.
The harness off the back of my Alpine Head Unit has a blue/White remote turn on wire for an amp. I do not have a amp so I connected that wire to the Blue/White wire that connects the Alpine Head Unit to the Mazda Blue/White wire.
Is that okay I firgured that the connection will just run and stop at the harness correct?
The pic below is the Mazda harness and the circle is the wire I connected the REM wire to.
I connected the power antenna to the blue wire, and the rem wire to the blue/white wire of the mazda harness.
I dont have a power antenna either. figure they just loop the circuit instead of taping it off?
The harness you've got is universal as they had some models that came with amps. Hence why you've got the wire. Just on the vehicles harness clip you'll notice there's no wire opposite that slot.
@Deiimos Hit it on the spot from the beginning of a bad ground. Excellent! Im happy to hear that you went through some procedures to locate the...
20
I would pull it and bench test it with a 12v battery. Ive had Bulbs burn out in the past and the amplifier works excellent. They will burn out at...
Some equipment like AMPS comes with it no owner's manual. So the lights blinking on or off has to be taken somewhere else. Search engine. Car...
You've read an outdated book...most of us learned things by either trial and error or someone more experienced helping...not a 20+ years old book 🤣🤣🤣
I am installing a Maestro SW, steering wheel control in a 2008 Honda CRV. When I flashed the unit it gave me instructions stating that I needed...
kevinmcc2
kevinmcc2
Pittsburgh
audiobaun
