Blown fuse? yes or no
ed_rob
23
ATL
I think i have a blown fuse in my power wire or in my amp, I dont know but i had my power wire to connected to my amp but the amp was not connected yet. I install my amp today and no power to my subwoofer. What could be the problem.
you can usually tell when a fuse is bad just by looking at it. (there is a piece of metal inside that should be connected, if it is bad, that metal piece would be burned up).
a couple of things to check:
+12V connected to the remote input?
a good ground connection?
Fuses are easy to check.
If putting in a new one solves the problem, you know it was blown //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif :D
You have a dmm? Check the voltage input on the power wire, remote wire, RCAs and the speaker output. Could make it much easier than just guessing //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif.
ed_rob
ed_rob
ATL
bimma85
