blown coil
I have a blown coil on my DVC, I have two 12" DVC at 2ohm, is there a way to wire the good sub with the other sub with a bad coil so they both work? I checkd the ohms on the bad coil n it reads 0ohms but the rest all say 2ohms. Can I fix the bad coil or wire them all together with out the bad coil?
Im askin wut is the wiring for my good sub to wire to a 2ohm or a 1ohm?
IF each voice coil of your good DVC sub is 2-ohms, then wire them in parallel (VC1+ to VC2+ to amp+; and VC1- to VC1- to amp-) and they will present a 1-ohm load to your amp. IF you want a 2-ohm load to the amp, then only wire one of the voice-coils and leave the other one unconnected. Just keep in mind that one voice-coil of a DVC speaker can only handle half of the speaker's total rated power. If you want more specific info tell me what brand/model sub and what brand/model amp you have.
Isnt nothin big but the subs are:
Power Acoustik
Model P3-12W
The amp:
Planet Audio
Model AC3000.1D
Isnt nothin big but the subs are:power Acoustik
Model P3-12W
The amp:
Planet Audio
Model AC3000.1D
OK - what I said above still applies. Here is how you wire your good DVC sub to create a 1-ohm load on the amp...
Do you have any other questions?
What amp and Ohm load are you running? What are the dimensions of the enclosure? sealed or ported?Tuned too? You may be better off buying a pair...
981
  • Locked
I have a zapco 4.0 and 6.0 that was stored in an area near the beach and corroded it pretty bad. Never was powered since it was stored working...
14
4K
Everyone I found the problem it's the RCA cables, I had my electrician mate have a look and he pulled one of the cords halfway out and the subs...
14
Chief612
Chief612
Mpls, Mn
Jepalan
