Blown coil? Bad amp? I'm confused....
skullsmasher
ca
Subs: 2 rockford fosgate 10" punch 3's 2 ohm---
Amp: rockford fosgate 1000w amp (2ch I think, has ++-- connections)
its a 2ch rockford fosgate p6002 amp, so 600wx2 or 1200wx1
Ok One day my subs just stopped working but I never changed anything.
I noticed the amp was apparently still getting power because the power light would come on and respond to the bass, though none way actually coming out of the subs.
I took the subs out, checked the wires (Wired for a 2ohm load) and the only thing I noticed was one of them had a coil cover flapping off of it partially.
I glued the flap back down and tested each of the subs, one at a time, by themselves.
Each sub, when I connected to one coil, sound would come out. But also, on each of them, one coil, when connected, would not work.
Is that normal? Do both coils or one primary coil, need to be connected first, for the other one to work as well?
I put them back in and still, no sound.
All wiring seems to be fine too.
Help please.
yes.
maybe a stray piece of metal|wire down in the motor? maybe from the spider disconnecting???
wait, one coil on each SUB doesn't work?? hmm.
yea, one each sub, when I hook up only one sub, one coil at a time, one coil works and the other doesn't. //content.invisioncic.com/y282845/emoticons/mad.gif.c18f003ab0ef8a0d9c27ca78d77a6392.gif
blown coils. 1 per sub. weird.
find out if your amp is mono or stereo. the ++-- doesn't matter. a lot of monos' offer that for convienence.
depending on how you had the subs wired, a stereo amp may have been to blame.
how were they wired?
bump. i dont know how to tell if the amp is mono or not, //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
I missed the model in your first post. Rockfords model numbers i think were close to MAX numbers.
here's a quick link
http://www.cardomain.com/item/ROCP6002
150x2 @4 ohms. it does have VERY low distortion, so I'd figure in a good bit of headroom.
how did you have the wires coming off the amp? 1 set to 1 sub, 1 set to the other, or 1 set to the left coils 1 set to the right maybe?
I missed the model in your first post. Rockfords model numbers i think were close to MAX numbers.here's a quick link
I had it like the first and second wiring options on this page, top one and the one below it.
http://www.rockfordfosgate.com/rftech/woofer_wizard.asp?submitted=true&woofer_qty=2&woofer_imp=3
Whatya think?
skullsmasher
skullsmasher
ca
skullsmasher
