blowing subs
nickmell
md
im the past 6 months i have blown a 12" digital audio and 2 8" cv subs running off a sony xplode 600wat amp but i cant figure out why. i wasnt listening to any hard bass tracks and dont think i was over powering them ( ran 2 chanells bridged for the 12 at 2ohm impedance. i only have stock on the big three for now and i just found that the cable from the negative terminal to the frame was broken and looks like it has been that way for a while , so could that have been some of the problem?
im not sure wat i had the gains on ill look when i get home i think i had them turned up most of the way ..... wat is a dmm? im pretty new to this stuff. also wat would be a good amp to get for kinda cheap? i race dirtbikes so most of my money goes in to that so i cant spend a whole lot... thanx
dont think that amp is stable at 2 ohms bridged but the gain setting is dependent on what load it is seeing. personally i would sell that and put a lil money with it and get something better. you can pick up a decent used amp for under 100 bux that will be much better than the one you have.
i had my gains maxed out wat should i had them at?
There's your problem.
The gains are input sensitivity adjustments, to compensate for the various strengths of signals coming from different brands/models of head units. One h/u might put out 5 volts while another only puts out 1 volt. Turning your gain all the way up is like assuming you have the smallest signal voltage possible (fraction of a volt), the amp is working its hardest and is being pushed into clipping. This will increase amplifier output well above listed specifications, and can/will mean premature failure of the speaker(s) connected to it.
A 'mono' amp is not inherently better than a 2-channel amp for subs. Nor would simply switching over to one solve the OP's on-going problem.
nickmell
nickmell
md
audioholic
