Blocking Pages With Firefox
You're funny....
I don't think there's a way, but if you can't find a firefox solution, a system-wide solution could be just to edit your hosts file to point to something non-existent. Add an entry saying:
Code:
127.0.0.1             caraudio.com
127.0.0.1             www.caraudio.com
127.0.0.1             forums.caraudio.com
Hopefully you don't run IIS or a web server, or you could just use 0.0.0.0 instead of 127.0.0.1
All this is doing is when the browser needs to find the IP address of the server, instead of looking it up on the internet, it's gonna see, "I already know what it is...it's 127.0.0.1" in that hosts file & use that instead. Some people use it for common typos of web servers...like if you typed whitehouse.com but really mean whitehouse.gov...you'd add an entry with whitehouse.gov's ip address but with the hostname of whitehouse.com.
Hosts file is @ c:\windows\system32\drivers\etc in XP
Thanks for the info!
Seems a little too complicated for me though //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Come on man...all you would have to do is this:
1. copy & paste this stuff into notepad:
Code:
# Copyright (c) 1993-1999 Microsoft Corp.
# This is a sample HOSTS file used by Microsoft TCP/IP for Windows.
# This file contains the mappings of IP addresses to host names. Each
# entry should be kept on an individual line. The IP address should
# be placed in the first column followed by the corresponding host name.
# The IP address and the host name should be separated by at least one
# space.
# Additionally, comments (such as these) may be inserted on individual
# lines or following the machine name denoted by a '#' symbol.
# For example:
#      102.54.94.97     rhino.acme.com          # source server
#       38.25.63.10     x.acme.com              # x client host
127.0.0.1       localhost
Save As...
And copy & paste this in:
Code:
%systemdrive%/windows/system32/drivers/etc/hosts
If you f*ck up or want to enable access, just delete the last 3 lines.
ss3079
Eh Dere Hi Dere Ho-ser
ss3079
Up North
ss3079
