Blew my PA DB1212 ffs!
Alex K
Big Meat marty
So I'm at the school parking lot, showing my friend my sub I got from Crutchfield, and it's sounding great. I'm powering it with a Kicker 400.1 400W amp, gain is tad past half, same with bass boost, and set at 80hz. He just got done asking me if I had ever blown a fuse with it, and next thing you know it smokes and shuts off.
I noticed it smelt burnt from the start sence I got it, but I figured that was a "new sub smell". I got a full refund for it, but anyone have any idea why it just blew on me? I didn't overpower it at all!
Might want to change your comment on crutchfield Alex //content.invisioncic.com/y282845/emoticons/tongue.gif.6130eb82179565f6db8d26d6001dcd24.gif
The bass boost and its only rated for 360rms most likely your problem. Going by crutchfield, I am assuming the imp. load was at 2 ohms which is a 400 or better RMS from the Kicker amp at 2 ohms.
incorrect box, incorrect tunning, and dc'ing, probably starving amp for power.
Burnt VC are not warrantible (such word?) either install or operator error!
Incorrect Box? It's the factory box that comes with the DB1212.
http://www.crutchfield.com/p_107DB1212/Polk-Audio-db1212.html?search=db1212&ssi=0
Incorrect amp?
http://signature.crutchfield.com/s_2068ZX4001/Kicker-08ZX400-1.html?search=400.1&ssi=0
Incorrect tuning? X-Over Freq at 80 hz?
Gain at 5th notch on Kicker amp?
Bass Boost at 4th notch on amp?
Starving the amp of power? Kidding me? 4 Gauge wire, sanded chasis, and secured ground?
I'm pretty sure I did everything right. I'm almost positive since the sub smelt "burnt" from the beginning it was manufacture fault. Not mine.
Alex K
Big Meat marty
Alex K
Ft. Worth, TX
Alex K
michigan born
    May 14, 2026
michigan born
    May 14, 2026
