While almost anyone could benefit from an electrical upgrade, it really won't cause major problems unless you're dipping down to ~11V on a regular basis.Test while using a DMM hooked up to your amp's power terminals (not measured at battery). If you see voltage drops, you have problems. No voltage drops, no worries.
I see WAAAAAAYYYY too many people on here with total overkill for a charging/electrical system, thinking they need it. As stated above, you only need it if your voltage is dropping into the 11s. If you wanna hold peak RMS, 14.4 would be ideal, however most quality amps are rated at 12V or 13.8V, cheap crap is 14.4V.
I run a 125AH deep cycle WALMART Maxx marine battery ($85) and 1200RMS off of a stock 80 amp alt. You should upgrade your battery and grounds before anything else.
