blew my amp.. pics inside!
newyorkjets00
so i was a dumbassss and used the same color for my positive and negative on my fosgate 450s amd smoked poured out so i turned it off quick.. looked and seen i hooked the negative in the postive on the amp and the power into the neg on the amp ****it... here are some pics of the damage.
It'll buff right out.
My brother did this to a Zapco i250 I installed (switch polarity)... and it blew about 5 fuses before we figured out what happened.
But nothing was charred. It worked perfectly.
Zapco > RF.
And it looks like you just blew a fet. Could fix it for pretty cheap, probably.
prime example of why i check everthing 3-4 times before i start it up the first time. Everyone makes mistakes though. I had my fare share when i was a teenager and just starting out.
A buddy of mine hooked his Linear Power 5002 up backwards when we were in high school. A little bit of smoke came out of it, but to our amazement, it still worked and nothing was charred on the circuit board. We both learned a very valuable lesson.... You shouldn't try to hook up your amp when you are drunk!
what exactly is the little squares the run down both sides? it just looks like the first one is messed up can it be fixed? the amp still turns on..
That would be a MOSFET that you blew to high hell. You may have a matching one next to it or on the other side of the board. Depending on how bad you burned the circuit board, you may be able to repair it.
newyorkjets00
newyorkjets00
Lake Whitney
newyorkjets00
