'98 Blazer - anyone care to quickly run through the removal of the stock head unit?
Much appreciated.
I have a 1997 Bravada......should be roughly the same.
Take the dash trim off- its one continuous piece.....goes to the left of the wheel, covering the switches, over the gauges (two screws in the top of this), and to the right of the wheel, over the radio and climate knobs. There are just those two screws above the gauges, the rest of it pops off.
Open your driver door, you can prop it up there, so you dont have to disconnect all the switches on the left side.
After thats off, just take the hex bolts out- dont forget the four around the climate knobs, you have to remove that so the dash kit (assuming youre putting in an aftermarket deck) lines up right.
If bolt sizes are the same, youll need a 9/32 socket.
Not too hard at all......
Just be careful not to break the plastic trim.
