Black amp, direct sunlight.
qtipextra
The Original
I have this stupid little 2 ch amp, 140 watts MAX. I am going to have it power my 6x9's. My question is, as the subject says, my amp is black and where I would like to mount it gets direct sunlight during the day. Would it get too hot to turn the amp off due to temp overload, or do you think it will be allright, or do you think I should paint it white? Or would paint just keep the heat in the amp?
being in direct sunlight may affect the performance of the amp. keep in mind that an amp stays cool by using the metal cover as a heatsink. therefore, a sun baked heatsink won't allow the amp to cool efficiently. i would sand the black paint to bare metal. you can then brush the metal, which most likely is aluminum, and give it the brushed aluminum effect. then again, like you said, it is cheap and ugly so i don't know if you want to go through all of this trouble.
I wouldn't reccomend putting your amp in view of sunlight/the public for security reasons! Last thing you need to worry about is a overheated amp when some kid smashes out your $300 window for a $80 amp.
some of us don't have a choice...in my van, for example, the only place I could get enough flat space on the wall was right across from the side window, so the amps are in plain sight. Nothing i could do about it...
to the original poster, run a relay off the remote wire, so the fans are switched along with the head unit.
qtipextra
The Original
qtipextra
Idaho Falls, Idaho
TomZ keren
NorthFramingham
    Jun 30, 2026
