Birch vs 3/4 MDF SPL box
As I said this is the first box I've had the Issue with coming apart at the seams but I have done every box the same.. One Piece at a time let dry for 3-4 hours then do the next Piece. Pre Drill all holes for the screws etc... I have had 3 MDF boxes where Screws would basically pull out with the sub. #8wood screws 1.5" long , And have had 1 box that I used all threads on and it basically pulled the washer & nut halfway through the MDF... But 4 boxes out of 30 or so isn't that bad of an Issue as It could of been bad wood from the shop or User Error / Moisture Buildup or something else..
I actually bought this pre made from a friend that was rocking it in a Tiburon. I needed a box 3 days before a show. That's why I want to make sure this new box is done right
18mm Baltic Birch is used in Pro Audio sub systems that handle that kind of power for a reason..It is lighter and stronger. About the only advantage of MDF is the cost...if cost is not the issue, then use the superior material.
So your saying that Birch is acoustically equal to or superior than MDF?
I use plywood and I have talked to guys that have done world records that use it. Brace when appropriate, double layer if you can, and the only difference is weight, weather resistance, and how much easier it is to work with.
I was in Lowes looking at the wood and plywood looks much like birch. Can't remember the price you
[/QUOTE]
fuck birch....I don't like how it machines vs mdf
Just wheel my table saw out of the garage onto the driveway, dust problem solved. Same with router and sander
---------- Post added at 09:01 AM ---------- Previous post was at 09:01 AM ----------
and like the others said....if your box is blowing apart then your not building it right lol
this whole thread depends mostly on what TYPE of birch plywood you have......is it 5'x5' Baltic Birch?....as I said earlier..it is superior, but you need to know exactly what type you have, because some "birch plywoods" have lesser qualities/thickness.
I didn't build the first box. I only cut the second face plate and jigsawed the holes for it because the original holes were cut too big
yea, it is stronger and you need sharp tools and a slower feed rate....but I have literally machined both and the Birch won't gum the cutters as bad as MDF
Also, don't get birch from a hardware store like Lowes or HD. Their Birch is not void free, it can be ordered by they will **** you in charges for that. You are better off finding a lumber yard that will allow for direct sales.
xSPLoder
o_0
xSPLoder
The Roc, NY
disturbed471985
