Biggest DD amp i can run with no drop?
what coils you have? if you can get the M4 and wire it to 2ohms it would be bad ***..@ 2 ohm its going to be more efficent and cleaner.
9500s don't have a big coil. a solid 2500(real power) is more than enough they can handle 3k but you don't have to have that much to make um pound.
are you never gonna get another one?
are you dead set on DD?
I'm only going to run 1 18 and yes at this point it has to be dd.
sharkman whats your budget ma boy?i don't personally now him
As of now I don't have a budget. I was thinking about getting the new m3c I found a a dealer a few hours from me for $900. At this point I need to know what direction I should go and work towards that
**** man. if you really have no budgt this is hte baddest mono block i know of..
KS2500.1 - Arc Audio Monoblock 2500W KS Series Amplifier
they are clean like AB but alot more efficient ruffly as efficient as a class D without the downfalls like low dampening factor and poor noise floor.
its gonna sound cleaner and louder. ive seen several do around 2950-3k @ 14.4..
next would be zapco SQ monoblocks. but the m3 isn't a bad choice as well..
If you're serious about the hobby I would go as big as budget allows. Although something to keep in mind is if you decide to move bigger later on you can always strap, so the M3c may not be a bad choice. Also DD amps retain their value pretty well. If you decide to switch up or get out of hobby it shouldn't be difficult to get a decent amount of your money back.
You should be fine electrical wise, but I would personally test the waters before you tried running at .5 for daily without a care in the world(if you were considering that). Lower impedance = mucho current and less efficiency not to mention heat.
oh yea. KMSL. let me see you send that woofer to get annalist testing on hormonics and even parameters. i bet you stop using them..
I'll show you the score card that says your test don't matter.
---------- Post added at 12:57 PM ---------- Previous post was at 12:57 PM ----------
Not really sure why a few people are mentioning the m3a over the b? From the specs the b puts out more power right?
They don't know which series they are on. Get the newest.
sharkman
poor bass head
sharkman
oakland ca
Papermaker85
