bigger = louder??
kwitcherbichin
ok this is about box port sizes like 3 inch port 5 inch port...
i see some boxes that have MASSIVE ports then some boxes that have small ports...
wtf is bigger ports made to do burps or what cause i got 2 12s and there the XXX 12s and i made a box tuned to 27 hz obviously for the lows...
now if i made a box that was tuned to the same hz would BUT with a bigger port would the output be more or less...
currently its a 3 inch L port
but idk im new to this box mess so w.e info u all have lets hear it
How can those ports be 18" long if they are basically the same length as the diameter of your 12" subs? At this point I dont trust your numbers to give any advice. Nothing personal, just saying find a tape measure.
well for one its 17.5 inches or i can read... its bigger then what u think...
heres a pic just to show its from the insides of the port -_-
more port will move more air.... doesnt necessarily mean its louder to the ear.. it will be louder on the mic though....
not entirerly true / can be too much port and cause unloading /would need to be real big though
the box is roughly 7.5 cf i think cant remember and dont wanna go back outside to check
i was just askin a question if i had a bigger port would it be louder but idk y i asked that cause the box is tuned low...
but if it would move more air that was what i am lookin for ...
but thnx 4 the help
I was wondering the same thing honda xxx. Too bad people are just out to flame huh? Guess we will just have to build a different box with a bigger port to find out. My situation is this.... aq 2.5 10 inch sub in 1.25 net with 25 sq inches of port tuned to 38hz. So if i kept the volume at 1.25 but made the port 35 square inches and kept tuning at 38 by lengthening or shortening ( whatever the program calls for) would it be louder or would it just unload the sub.I am under powering so it shouldnt tear anything up. Maybe someone "else" will post here and help us out.
Well Im still confused, because your video seemed to show the port approx the same length as the diameter of your speakers. Sorry if you consider this a flame, I just really dont see how things add up here. 12" speaker, 18" port. The video should clearly show a discrepancy in the size of these two objects. Am I seeing the enclosure wrong or what?
More port area is not always better. More port area allows the enclosure to unload faster below tuning (bad for music after some point) and increases port length to keep the same tuning (bad for SPL at some point). The port length and port area provide a resistance to air flow that, in conjunction with enclosure volume, creates port tuning.
Imagine blowing through a straw. If the straw is large enough diameter, no matter how long it is, it will create no resistance to your blowing motion. It would be like blowing into mid-air, not a straw at all. At this point, the enclosure would like much like an infinite baffle situation as far as cone motion is concern, but without isolating back waves from the front waves.
Hope this answers your question.
kwitcherbichin
kwitcherbichin
stantonsburg, nc
kwitcherbichin
AJ (ACE)
    Jun 28, 2026
