Big question- JL subs- ohm config's- what would you guys do?
boomzabit
I cant seem to make up my mind fully. I was waiting on a guy o get back to me on an older xxx but i dont know if i want to wait around much longer, plus i still might buy it just to have it..
As of now im running a 10'' W7 ported and im fairly satisfied although id like alittle more force on the low end.. its hooked up to a Sundown saz 1500 as well. I was thinking of finding another 10'' W7 and running them both at 1.5 ohm's so i can use the power of my amp alittle more rather then run one sub at 3 ohm's. Ive been reading on w6v2's and heard they are pretty decent all around have good SQ, and they are dual 4 ohm. If i ran 2 w6v2's i could run them at a 1 ohm load since my amp is 1 ohm stable. Now heres the (2 part) question, say the subs both get recommend ported box volume tuned to the same hz. What would most likely be louder between 2 10'' w6v2's or 2 10'' W7's? The w6v2's would be running a 1ohm vs the w7's would bring a 1.5ohm load, say the w6's are getting 750w a peice and the w7's are getting about 600w apeice..
BTW, i could get a deal on some 12'' w6v2's if those be better a option for more forcefull low end.
boomzabit
boomzabit
Minnesota
boomzabit
