big 3 upgrade questions
quins90lac
ok planing on doing the big 3 upgrade to my car and my question is can i get away with doing it with 4awg ?its the same size as the power wire i got running to my disto block and its got a place for 2 8awg coming out of it.also the wire that goes from my alt to the bat looks like its only 8awg. so would going with 4awg be worth it also do i have to put a fuse in between the alt and the bat with only going with 4awg?
1/0 awg means that its perty much imbetween 1/0 . they call it 1/0 cause if you have ever noticed that wire gauges go in even numbers so next one down from 2 would be 0 but since it not quite 0 its called 1/0 at least thats the way i understand it to be.
FAIL!
1/0 = Literally pronounced "ONE OTT" meaning literally Single Zero Guage.
2/0 = Literally pronounced "TWO OTT" meaning literally Double Zero Guage.
And so on, and so on.
Since the lower the number, the larger the wire... 2guage, 1 guage, 0guage, 00guage (2/0), 000guage (3/0), etc, etc...
Also AWG = American Wire Gauge...
//content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
nG
FAIL!
nG
okay thanks, I found the chart on wiki, if im going to be putting around 1600-2000 rms from the battery, will a 2 gauge wire be sufficient? The more watts you output, does the gauge of your ground wire make a difference?
dont use wikipedia...
if youre really running above 1000 watts you should be running at least 1/0 power... youre ground should be AT LEAST the same size of your power, if not bigger.
K, so for simplicity sake your power and ground should be the same gauge.
quins90lac
quins90lac
peoria IL
quins90lac
