timelessr1
Hey guys! I have a slight dilema. I'm doing the big 3 upgrade in my prelude, but i ran in to a little issue. First of all the positive wire off the alt is wrapped in with other wires, and then runs over/through the engine and goes to the main fuse panel. It might not really be feasible to change that. Now there is another wire that goes from the positive battery terminal to the same fuse panel.
Ive already upgraded the stock negative that went to the transmission ground with 0 gauge. and also added another 0 gauge to the chassis of the car.
My question is...should I go from the Alt straight to the battery? now if i do go straight to the battery, does this mean i can remove the one stock wire the agoes from the battery to the fuse panel? the reason i ask is on the JL battery terminal there are only 3 holes. Currently one of the holes is for the 0 gauge going to the stereo, the other hole is for the starter wire, and the third is the wire that goes to the fuse panel.
Any help??
Any help??
