Big 3 upgrade and extra battery
LegendaryLemon
I'm running a pair of eD 13ov.2 D4s (bought during the sale) and some eD 6000s component speakers. They are being run off of a JBL BP1200.1 amp and a kicker kx600.4 amp. I've got a stock alternator (70 amps I believe but it may be 80) and I don't really want to spend $300 to get a new HO alternator for my 1995 toyota corolla that I'm only planning on driving for the next 2 or 3 years.
I just want to confirm my list of equipment to buy :
(10-12 ft) 0 gauge Kolossus Kable wire (haven't measured yet but I will)
(6) 0 gauge crimps
I won't need a battery terminal for this correct?
For the new battery I was thinking of throwing a Kinetik 800 in the back since space is limited.
For this I was thinking of using a pair battery terminal such as http://www.knukonceptz.com/productDetail.cfm?prodID=KBT-30N one so that I can ground my amps to the battery and another to connect the power wires. The battery will be connected via a 0 gauge knukonceptz kolossus kable run from my starter battery.
Would I be better off using my distribution block for connecting the amps to the secondary battery? This way I don't need to buy new fuses or anything? Or will this negate some of the benefits of running a second battery?
The way you want to do it should be fine. It's often recommended to put a fuse just before the second battery to prevent shorts. And you can definitely connect the amp to the secondary battery with no problems.
LegendaryLemon
LegendaryLemon
Maine
Goindef154
Mike Mccabe
Giles
    Jun 27, 2026
