Big 3 Question
what kind sand paper should i use all i have is like 150-200 grit sand ppr but ill try to get some later
that grit should be fine, you just need to get the paint off so that it makes good contact with metal. I spray a little paint over the contact point just for cosmetics and a little rust protection.
so i dont need a fuse right now right i will get one later then just put it 6-10" from batt going to alt + cuz i have a fuse going from batt up front fused to batt in back then to amp should i run a fuse between back batt to amp its only like 5-6 " so i wasnt sure
what ya wana know fuse in between alt + to batt + . some people dont do it if u have the wire on nice u came skip that .
But it dont matter if its placed on there nice or not, it can still cause a fire if not fused if he were to ever get in an accident. That is why you fuse it no matter what otherwise nobody would ever run fuses in there car if it wasnt a fire hazard.
i did not have one for my big 3 in my last ride. im goin to be doin the big 3 soon well thats if i run more power lol.I think if u have the fuse and holder i would go ahead and do it make sure u get your ring connecters on the wire good and use some wire loom if ya want..
jdmferio13
feayfm
jdmferio13
Central,PA
loopkiller
ThxOne
    May 13, 2026
ThxOne
    May 13, 2026
