Big 3 question for those whose battery is not in the engine bay
ace_800
So my battery is right behind my 2nd row passenger seat, so I'm trying to figure out the easiest way to run the Big3 wiring. Is there really anything I need to do different? I guess I'd need to run a 0/1 wire from the block to where the battery is like normal. Just additional wire I need now since the batteries not in the engine bay. There is a jumper terminal in the engine bay, just FYI.
I would just run a wire straight from the alternator to the battery and keep the stock wiring how it is. Just add-on 0 gauge to everything else (block to ground, batt to ground)
My battery is in the trunk and I'm going to do it this way. You could just upgrade all the wires if you wanted to, but my way is easier lol.
If it is a unibody car, your going to want to run your negative all the way to the front as well. Otherwise, you can ground the battery to the chassis in the rear, and the chassis to the block in the front.
ace_800
ace_800
Okinawa, Japan
ace_800
michigan born
    May 14, 2026
michigan born
    May 14, 2026
