Big 3 help pic
you can run it through, but i dont know if the fuse holder will be large enough for 0/1 gauge, you could just use a different fuse holder though
NO!! He should NOT run it through the stock fuse... Why do you think they have a stock fuse on a stock wire for? You want to fry his stock wires?
OP needs to run directly from the Alternator to the battery with a separate fuse sized for the wire...
x2
Any wire from most companies is a good one to get... You have to watch some companies though as they may sell you a smaller copper diameter wire with more sheathing compared to a larger copepr diameter with less sheathing. most local audio companies will have spools you can buy by the foot.
Ben_Davis
Ben_Davis
Mesquite,Nv
Boulderguy
