I'm currently in the process of doing the Big 3 and I wanted to make sure I'm doing it right. My alternator is mounted a bit deep and in a constrained spot so I don't think I'll be able to use it's mounting bolts for the engine -> chassis wire. I took some pictures of where my alternator is located and where I think I can mount the engine block (since the alt is mounted to it, it should work the same right?) to chassis wire. Basically I just want you guys to double check and make sure I can use these bolts, or perhaps I can provide more pictures and you guys can see what bolts I can use.
Here's the alternator deep at the bottom (click for big picture):
and here are two bolts I think I might be able to use:
Are those the correct bolts to use or not?
