tc300
also the factory cable is long as hell!!!! it goes around the coolant res. and under the front part of the motor. its kinda weird..
ya that why i just followed it and end up with 5ft long piece.also the factory cable is long as hell!!!! it goes around the coolant res. and under the front part of the motor. its kinda weird..
nothing special right now. 2 kicker CVRs. about to switch to a pair of type Rs off maybe a sundown 1500 or hifonics 2008D something with at least 1500 watts.so still not that great but being a poor college student sucks.hey 99.... what do you have in your trunk???
When you did yours did you leave your factory alt cable connected with the new alt to battery cable on as well? Or did you just leave it disconnected?i did it on my 99, and it was not bad at all. yes the alt to battery ending up being like 5 ft long. i ran it from the battery behind the coolant reservoir and around to the alt. the ground was easy as the factory ground spot it like 6 inches, so I just took the factory ground off sanded that area add the new 1/0 and put it on top of the factory wire and spot.
no i left it connected, put the 1/0 ring terminal right over the old one.When you did yours did you leave your factory alt cable connected with the new alt to battery cable on as well? Or did you just leave it disconnected?
I know its not to much right now, but I want to be prepared for the future.you really dont need an HO alt with what u got in ur sig.......
Cool. Thanks, I'm gonna go do it right now.no i left it connected, put the 1/0 ring terminal right over the old one.
ya no problem. also where did you get your ALT and how big of a box did you fit in the trunk?Cool. Thanks, I'm gonna go do it right now.
