Big 3 Fuse
The only way I see that you could have a problem with fusing the big 3 is if you had more current than the wire could handle. Say if you have 0 gauge, and a 200 amp h/o alt. Most 0 gauge is rated at 300a, so I don't see a way that you could possibly have a wire catch on fire, expecially with that short of run. Not unless you have a 300a+ alt.
You fuse that wire with what amps/ voltage the actual wire can carry, not the alternator. If you're using 1/0 wire use a 200-250 amp fuse. Some people don't do this, which can lead to your car on fire if anything bad happens.
Agreed, which is why it is reccomended, and most 1/0 is rated at 300A not 200A.
I realize that, but as far as the alt goes I don't see how anything can happen to the wire if the amperage of the alt is less than what the wire can handle.
well my old stock wire to the alternator did not come with a fuse so i was wondering if i can add another 4 gauge at the postive of the alternator attachin to the old stock wire and run the new 4 gauge with a fuse seprate way to the battery and leave the old stock wire where it was with no fuse and heres a picture link to show you what i am kind of talking about
http://i480.photobucket.com/albums/rr162/hifonics98/jeep_grand_cherokee_engine.jpg
well my old stock wire to the alternator did not come with a fuse so i was wondering if i can add another 4 gauge at the postive of the alternator attachin to the old stock wire and run the new 4 gauge with a fuse seprate way to the battery and leave the old stock wire where it was with no fuse and heres a picture link to show you what i am kind of talking abouthttp://i480.photobucket.com/albums/rr162/hifonics98/jeep_grand_cherokee_engine.jpg
Pic shows you running wires to the Air Conditioning Compressor......This will not help:fyi:
i know that because the alternator is under the ac compressor and could not show it in the picture
as long as you realize this....//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
If you are worried about Fusing, then there should be a fuse between any power source(batteries/alternator) and a potential grounding situation. I did not fuse my big 3 and have had no issues, but I also have not been in a wreck and ran my wire such that it did not have any chance of being pinched and grounded.
And the fuse is intended to protect the wire....So fuse according to wire gauge being run.
The stock wire is effectively a fuse due to how thin it is. The manufacturer never used a fuse because the wires they run are out of the way of any moving object. They also assume that if you get in a crash that might cut that wire, the engine will stop running anyways. That wire coming from your alt usually goes directly to the fuse box, then to the battery. So if the engine is not running due to the crash, and then the wire is grounded, the fuse will pop due to the battery supplying the current.
Cliffs, to be safe, always fuse any POS+ wire you add. It is a $10 insurance policy. Fuse based on wire rating.
Its fused for any electrical SURGES that MIGHT happen...
ANY wire, nor matter WHAT size, can have a HUGE momentary surge that will overheat the wire and start an electrical fire which is VERY difficult to put out...
i am adding a new 4 gauge wire to the stock wire and the stock wire is 4 gauge and in my car manual its says it has a 175a generator mega fuse so idk if it was removed so would it be fine if i just buy a new 175a mega fuse and add the stock wire and the new 4 gauge wire
texicanz
texicanz
moline,il
texicanz
ThxOne
    May 13, 2026
ThxOne
    May 13, 2026
