Big 3 alt to positive question
I don't think fusing the alternator to battery line is a good idea, if its broken and unnoticed, the alternator will burn itself up i'm pretty sure. Alternators sensing no load is a very bad thing, last time i checked.
no way in hell that it will burn the alternator unless it was shorting its self out a blown fuse on a wire will never casue this and the fuse would only blow if it was shorting its self out. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
All right people, I appreciate your help here, but my problem will be solved soon enough. Believe it or not, there are other "noobs" that post in the Wiring forum that need help. GO! lol
Don't worry Chris. Many threads often go astray. Go ahead and read the latest sound dampening threads (if they weren't deleted) and you'll know what I mean. //content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gif
So you from the city or what we call "the country" of huntsville?
Well I'm not sure if you knew I'm from AL, but I know there's a Huntsville in TX, and it appears that's where you are from. Haha. But I'll answer your question anyway...I'm not in the country, I'm more in the metro area, actually right over the Madison city line.
Ok so I lied...I still have a question. If I were to ground the engine block to the same place as I grounded the battery, would that be a problem? Or should I ground it to a separate location?
Chris Z
Always wanting more bass!
Chris Z
AL
nineball
