Beyma SCK-65 component set
Tubermaguber
Dazed n confused
Rating: 50%
1 1 0
One set of Beyma SCK-65 components
Used for approximately 3 months in my truck. Perfect working condition and still cosmetically respectable. 6/10 (this is a harsh score, but there are minor flaws). One woofer has 2 of the mounting holes broken, though doesn't affect ability to mount or driver in any way and isn't visible with the grills on. One of the grills has some scrapes, that removed the paint. This damage was done while the driver's were sitting in my room, no dents or anything and of course no damage to the woofer. Great sounding set, imo, with stiff woofers and very clear highs from the 1" tweeters. The plexi for crossovers is pretty clean, still, but the mounting points show some stress from multiple removals. These are still in wonderful shape, just covering all my bases.
$80 shipped CONUS
Included in price
Can you get me dimensions and depth requirements on the mids and tweets please? This VW JSW is proving to be a nightmare with the doors.... Thanks.
Woofer Specifications:
Peak RMS Per Pair: 160 Watt
Peak RMS Each: 80 Watt
Peak Power Per Pair: 320 Watt
Peak Power Each: 160 Watt
Nominal diameter: 165 mm. / 6.5 in.
Nominal impedance: 4 ohms
Sensitivity: 90 dB / 1w @ 1m
Frequency range: 50 - 6000 Hz
Resonant frequency, fs: 56 Hz
D.C. voice coil resistance, Re: 3.6 ohms.
Mechanical quality factor, Qms: 2.26
Electrical quality factor, Qes: 0.98
Total quality factor, Qts: 0.68
Equivalent air volume to Cms, Vas: 13.2 l
Efficiency, ?o (%): 0.2
Effective surface area, Sd: 130 cm2
Xmax: 3 mm
Tweeter Specifications:
Nominal diameter: 25 mm. / 1 in.
Power handling / maximum: 20 W RMS / 40 W
Sensitivity: 92 dB 1w @ 1m
Frequency range: 2 - 20 kHz
Filter Specifications:
Power handling: 120 W RMS
Crossover frequency: 3.2 kHz
Attenuation slope: 12 dB/oct.
Mounting Information:
Woofer baffle cutout diameter: 147 mm. / 5.79 in.
Woofer mounting depth: 66 mm. / 2.60 in.
Tweeter baffle cutout diameter: 46.5 mm. / 1.83 in.
Tweeter mounting depth: 20 mm. / 0.79 in.
Filter external dimensions:
115 x 90 x 39 mm.
4.5 x 3.5 x 1.5 in.
Silk tweeter? What do you need trade wise?
Glass/fiber woofer, and sheet just says fabric tweeter diaghram. Tweeters sounded more pleasant to me than the Image Dynamics XS-28 I'm currently using (without eq). The ID's sound more harsh and "tingy" unless they are very on-axis. The Beyma's were slightly warmer sounding, without being harsh or warm, just clear. And plenty of volume despite the low power handling.
As far as trades, I'm not after anything in particular I don't guess. Just entertaining offers.
Tubermaguber
Dazed n confused
Tubermaguber
McGehee, Arkansas
Uncle Snake
