I've always wondered which is better, using the HP/LP filters on the head unit or amp. I am guessing it is better to filter the signal at the source (HU) and run pass-through mode on the amp.
i always filter on the amp as there is typically much more flexibility. or maybe i have just used too crappy head units with only one or 2 settings for crossover points.
I use my headunit because its filters are much better than on my amps and my headunit does all the other processing so the amps should just amplify the signal, not modify it. I run all my amps full range to all speakers and I filter the signal before it gets there.
