Best way to wire up my 2500d?
SkwurlyFab
SD
Would it be better to use 2 runs of 0 ga from the battery to the Orion 2500d and use reducers to 4 ga into the power inputs.... Or would it work just as good to run 1 run of 0 ga from the battery to a fused distro with two 4 ga outputs that go to the amp?
Yeah that's another thing I was wondering, I'd probably use less wire if I wired in another battery into teh back of my trunk wouldn't I? Cuz then I could just run the power and grounds for my amps to the battery in back instead of all the way up to the front. I have a 4runner btw. Is that true TypeR?
So since you ran 4 positives and 4 negatives from the back battery to your amps, you had to match the same amount of wiring to the front battery correct?
I won't be running 2 amps, just 1 so I'd have less wiring, but it seems like it would be easier to run the wiring for the amps off of a battery in the trunk.
I like your set up a lot TypeR. Seems very thought out and straight forward, and from the numbers in your sig, looks like it's workin pretty **** well! So props on that.
SkwurlyFab
SkwurlyFab
SD
SkwurlyFab
