I have 3 JL 12W6s version 1. They are DVC 6 ohm and I have a Ti800.1 to power them. What do you guys suggest would be my best solution for wiring? I can do this two ways:
1) wire the subs in parallel with the voice coils in series, but then this would be a 4 ohm load to the amp. This would be an easy load on the amp but not a lot of power. or ...
2) wire both the subs and voice coils in parallel, but then this would be a 1 ohm load to the amp. I know the amp is 1 ohm stable, but this is a daily driver and I don't want to put too much stress on the amp.
I know my best bet would be to get 1 more 12w6 and 1 more Ti800.1 and then run 2 12w6 to each one for a 2 ohm load, but out of my options what do you suggest? I also have a Ti600.2 if that helps.
later.
later.
