Best way to secure an enclosure without bolting it down.
MONSONwarrior
Premium Member
Constantly Rebuilding...
My box slides around quite a bit and I was wondering what the best method to secure it down would be, minus bolting it down. I was thinking maybe velcro to the carpet? I'm not exactly sure what would be best.
EDIT: It also doesn't sit like it is in my avatar, it's laid down normally.
It's covered in truck bed liner, and yeah, I was thinking velcro would do a good job and if I put the loop down on the carpet it's still removable. My system is designed so I can just pull it right now when need be.
You could also think about cutting a panel in the same shape as the floor of your cargo area and bolting the enclosure to that. It would still be removable, but it'd take more effort to get it out...
Use a ratchet strap. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
That was considered.
Velcro works wonders.
Have used it in my car due to lack of places to bolt down (flimsy plastic frame over spare tire well). Held a 25lb battery tight as can be. Almost broke the plastic frame when it was removed.
This is being implemented.
Use a tub of bacon grease, and slap that shit on the area where the enclosure will be, it works wonders.
Will only work if 2 tubs are applied while singing "Mary Had a Little Lamb" in a Norwegian accent. //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
MONSONwarrior
Premium Member
MONSONwarrior
Baton Rouge, LA
slim2fattycake
