BFeezy 10+ year member Sneakerhead 1,000 1 NY Jun 12, 2011 #1 I have a 2000 Ford Taurus and I'm trying to run 0 gauge through the firewall... I can't find any holes big enough to run the wire through... should I just drill a hole? Is there a better way? Thanks Click to read more...
winkychevelle 10+ year member CarAudio.com Veteran 4,702 661 Ponchatoula, La Jun 12, 2011 #3 Drill a hole or go through the factory grommets by poking a hole in the grommet
fasfocus00 5,000+ posts doITdaWHITEwayORdoITtwice 5,712 58 New Orleans, LA Jun 12, 2011 #4 on most fords you'll have to drill a hole and use your own grommet.
Buck 5,000+ posts little alien on campus 35,960 5,673 Inside of a pyramid Jun 12, 2011 #5 1. Drill hole with step bit 2. Put 0 gauge grommet 3. Run wire 4. Silicone (P.S.) I have 4 runs of 0 gauge through my firewall.
LosIsATool 5,000+ posts CarAudio.com Veteran 18,504 73 Pensacola, Florida Jun 12, 2011 #6 So would advice to run it under the car and come up at the amps location.
